Hier einige "gesicherte" infos zu 500cc 2cyl.
-von einem absoluten Insider bei Aprilia zu dem Thema Aprilia 500. s.Text u.
-Die NSR500 hatte in der letzten GP Ausbaustufe 160PS am Hinterrad (gesehen bei Erv Kanemoto auf dem Dynojet) Die Teile haben aber nur ca. 2% Verluste zur KW
BTW die Vdue hat auch 72X61 HUB/Bohrung aber hier "nur" 125PS am Hinterrad s. Bild
GuFi
I think the first version was 400 cc with a stroke of 58,5, the maximum that could be reached because of the limited distance between the
crankshafts.
Engine power was very bad because of the, in my opinion, wrong engine dimension, a short stroke is no good for a 2stroke!
I think they never had more than 70HP from the single cilinder test engine. This means a very low PME! And this was only after they went to full cubic capacity! Before it was more like 60-62HP
This was not a project from Witteveen and Moro, it was only Witteveen's
The only thing Moro did was making a 7port cilinder that was worse than the normal 5port.
The carburettors used were far too small. On the dyno they even used a 39mm carb., on track 42 was used.
The only power improvements always came from raising the cubic capacity by increasing the bore.
I think it would have been difficult to do a worse job!
When the power increased the gearbox started to break, to be expected: it was the same as the 125's.
Then, finally they decided to make a full 500, with a stronger gearbox, but this was after 5 years losing their time.
And it was still a short stroke! Probably 72X61
Honda did not make the same mistake, their engine was 68X68,5, and they understood very quickly that it was inferior to the fours!
But I still think a well-made twin cilinder with rotary valves could have beaten the fours, even on topspeed!
Based on the PME we reached with the 125 a single cilinder 250 could have reached 82HP, which means 164 for a 500.
I do'nt think the fours had very much more at the gearbox output shaft!
And the twins aerodynamics would have done the rest!
Diagramm:
Vdue "Beste" blau
Vdue m. Vergasern grün
Vdue 100% Serie m. Einspritzung rot
