2x 1999 Harada
2x 2000 Harada
2x 2000 McWilliams
Engine Two strakes, 90° V2 cilinders, twin counter-rotating shaft, twin rotating disks, liquid cooling, electronically governed Rave valve on exhaust
Brake for stroke 72,8 x 60 mm
Displacement 498 cm3
Max power / revs more than 140 HP at 11.750 rpm (unleaded fuel)
Carburettors n° 2 Dell’Orto VHSD 42
Starter Digital CDI with battery
Gearbox Six gear extractable
Clutch Dry multidisk
Frame Double inclined beam in aluminium
Suspensions Ohlins reversed fork, diameter 42 mm with double hydraulic regulation. Progressive APS system with Ohlins adjustable shock absorber.
Swing Arm Main fork in carbon
Brakes Brembo
Front: twin 290 mm carbon.
Rear: single 190 mm steel disk with four piston calipers
Wheels magnesium alloy 17” front and rear
Dimension Weight: 110 kg
Wheelbase: 1.400 mm
