Vordere Achse : 180g ( stahl 270g)
Hinter Achse : 277g ( stahl 365)
Ersparnis eher gering da ich die Möglichkeit zum hohlbohrrn nicht habe. Der Bohrer läuft mir davon .
Der Kleinkram Hülsen etc brachte mir nochmals 220g Ersparnis .
Er arbeitet im Moment an einem 400ccm Zylinder .
Hier die Antwort :
Hi thomas I,m building a 400 kit for the vj22 motor it wont be ready for quite a while cause i have purchase and to set up the machines to do it but its going to be pretty cool... but this is what i am working towards and the carbon parts are funding the purchase of the machines so I can build the engine parts, so the more suport I get the faster it will happen....
yeah there coming tomas but it wont be to the end of this year as i still have to set up to build them, they will be bolt on kits for the rgvs vj22s consisting of cylinders o-ring heads they will have fully adjustable powervalves including adjustable auxilliry exaust ports. this means the whole set up can be tuned to whatever config you chose to tune your your motor to, they will use a tried and tested race port set up of an existing race bike, so the port set up will be garanteed to work ive seen many designers try to re invent the wheel so to speak with port design and they all failed so ive decided to go with a proven set up and refine it.. also will be available will be the 68 pistons to match and race rods which ive already this will give you mixed with my 54 crank or existing 54 cranks 498cc,ive chosen this cause it can fit into the existing crank case without any modifications and can be raced in the 400 class that i know some guys race in.
but i don't think it will fit any other bikes except the aprillas but there is also a kit being developed for the rg500 that will give 632 or 700 if you use the 54 cranks
Viel zu lesen Jungs , aber interessant was der Herr da in Planung hat
Ja . Wie gesagt die Cover sind gerade in der mache geht noch ein bisschen .
Der big bore Kit ist bereits zu beziehen , die Welle braucht noch etwas Zeit .
Nichts ist umsonst im Leben, nicht mal der Tod, denn dieser kostet dich das Leben :)
Damals auf der Suche nach Carbonteilen, bin ich auf ihn Charlie gestoßen.
Er hält mich auf dem Laufenden , gibt noch andere feine Sachen, auch für die RG 500.
150€
Jungs so ei Tank müsst ihr erst mal finden , in diesem Zustand ![]()
Es wird einen neuen 350ccm Kit auf dem Markt geben ,
hergestellt in Australien .
54 Kurbellwelle + Zylinder und diversen Carbon Teilen .
könnte interessant werden .
Auf dem Bild ein Prototyp
Schwingenachse + Einstelller Schwingenspiel Sicherung
Die Achse AWS 7075 nicht hohlgebohrt 243g ( STahl 400g )
Gesamt Erspanis mit der Sicherung
250g
Vorder und Hinterachse+ Motoraufnahme Hülsen und Spacer Räder + Muttern folgen
Das Tyga Zeugs verschandelt das ganze Motorrad .
Passt alles optisch nicht zusammen , alleine schon das Heckteil, viel zu hoch und zuviel Luft zum Hinterrad .
Rgv 250 vj22
Zu verkaufen sind :
VJ 22 Tank Gutem Zustand 100€
Sebimoto Racing Heck rot 30€
Frontverkleidungund Seitenverkleidung original in rot Lackiert 200€
Scheinwerfer 30€
Frontgeweih verkauft
Stahlheckrahmen 50€
Öl und Wassertank je 25€
Ölpumpe 40€
Rückleuchteneinheit mit Kunstoffunterverkleidung 60€
Blinker 10€
Zustand : alles funktionstüchtig und im guten Zustand
Preis VB
Macht mir einfach ein Angebot per mail
